Old 02-21-2005, 06:55 PM   #1
Now for waste gates
Ok peoples thanks to all ur wounderful help I am getting a to3/to4 hybrid turbo with a .63 turbine and either a 57 trim or a 60 trim. but for this I need a to make a new mainfold with the proper flange or a adapter flange right :S, and second what are my opitions for waste gate I take it either big can or external?
London Shelby is offline
Old 02-21-2005, 08:30 PM   #2
My Ride: 85 Charger
I have been told for the stock manifold you would use an adjustable wg can to preload so you can hold good boost. If you are running lower boost, like under 17psi, the big can should be fine- with the bracket adapter from TU.
john1320 is offline
Old 02-22-2005, 08:53 AM   #3
really :S I wanna run 18-20
Advertising | Car Accident Attorney Los Angeles | Myspace Layouts | Personal Loans | Problem Mortgage
Page generated in 0.25714 seconds with 13 queries
