Old 02-24-2005, 07:09 PM   #1
Thumbs down 12 psi with grainger?
Have an 87 Shelby daytona with 3 mods, no cat and a grainger valve, shimmed wastegate. problem is I cannot get over 12 psi. Do I need to shorten the spring in the valve or what are my options? i know that it had 12 psi all stock with the factory controller. A/F guage shows all is well at 12. I would just like a couple more psi.
Dusted U is offline
Old 02-24-2005, 08:11 PM   #2
no need to stretch the spring or get a stiffer spring. both are easy to do, stretching the spring you can do with your ifngers and buying a new spring is easy, go to a hardware store and take your old spring with you, grab the same size spring just a little stiffer.
1985ShlbyChrger is offline
Old 02-24-2005, 09:28 PM   #3
My Ride: 85 GLHT, 87 ShelbyZ
if the wastegate is shimmed and you're only getting 12psi I'd say the can is dead. try unplugging the vac line from it and carefully seeing if you can get over 12psi. If so then it's the grainger. If not it's the can. The can on my 87 died awhile ago. Wouldn't pull over 11psi with the 2.5 shoved under it.
GLHNSLHT2 is online now
Old 02-25-2005, 06:37 PM   #4
Thumbs up thanks
i shortened the spring in the grainger and found my 2 psi. 14 on the stock guage through all the gears.
Rob
Dusted U is offline
Old 02-25-2005, 06:43 PM   #5
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
After everyone told me you couldn't use a large can from a T1 Garrett, I swapped one onto my T2 turbo in California.. Works like a champ, I can get as low as 10psi, and as high as 25psi..
Una is offline
Old 02-26-2005, 09:54 PM   #6
I've got an early can on my TII Aries. Fits awesome.
cadmanspd is offline
Credit Card | Bad Credit Mortgages | Credit Cards UK | Bad Credit Mortgages | Electronics
Page generated in 0.46384 seconds with 13 queries
