02-25-2005, 09:25 PM
All compressor housings are not the same!
Originally Posted by puppet
All things being equal, inlet and outlet sizes, does one have an advantage over the other ... and why?
In comparing both side by side, the T2 is obviously larger but this size difference seems to be just in the radius that the compressed air flows. Does the tighter wind of the T1's housing hurt anything flow wise?
I ask because I have a early style MP+ turbo. Changing to the stock T2 housing will mean some machine work for the stock inlet. If it doesn't matter ... I'll go with the earlier style housing move on.
My MP plus turbo is not the same as a stock T2 Garett (blow through style intake). It has a 60 trim compressor on it (not a super 60). Although it looks like a stock t2 cover from the outside, it is bigger on the inside. So the stock T2 compressor cover will not fit over the 60 trim compressor wheel.
Is yours different? If it has a larger compressor wheel on it as mine does, the t2 compressor housing will not fit over it.
If it has a stock compressor wheel on it than you can use the early (draw through) or later (blow through) style (stock) compressor cover on it.
The overhang of the scroll and the radius you wrote about may be from the bigger 60 trim wheel.
Other than the inlet to the compressor, the stock Garett housings appear to be the same to me.
Joe Dzwil
