03-01-2005, 07:08 AM
MaxWHP with 93octane & stock head?
My Ride: 89 Lebaron GTC
What turbo would I need on a 2.2 and 2.5 to achieve Max WHP with 93oct gas on a stock 782 head? Assume spearco intercooler, 2.5" full exhaust, 3 bar calibration, 5 speed transmission. I'm guessing 220WHP with a 2.5/Super60 and 250WHP with a 2.2/Super60. You guys know any good setup combos? Dyno plots would help too!!
03-01-2005, 10:37 PM
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
Garret or a Super 60.
03-01-2005, 10:50 PM
No hybrid? Must I port the head to use a hybrid or will I suffer major lag? I want to use a 50trim/stage III but do headwork down the road with a rebuild. In the meantime, would the my 2.5/stock head/5 speed vehicle suffer due to the head being a major restriction?
03-02-2005, 01:58 AM
My Ride: '88 Sundance
Engine: '89 2.5 TI
FWIW, Alcohol injection has really upped the horsepower that our engines can make on pump gas. With proper tuning, the right turbo, a good flowing head, intercooler and exhaust, running alky for detonation control and extra fueling I'd bet a person could get upwards of 400 WHP on 93 octane. This is just a wild guess on my part though.
Tony
03-03-2005, 01:29 AM
My Ride: 2004 SRT4
Engine: 2.4
You can EASILY make 220 whp with the stock Tll turbo. you can make up to roughly 240-250hp with the stock turbo. You can make up to 300hp with the S60. A ported head is a worth while investment. Providing it was done right. You'll make more power per psi of boost. Even a mild port with stock valves will help alot. If your just wanting to make 220 whp, I myself would use the stock Tll turbo, get a full 3" exhaust. The best intercooler you can afford and get a cal set up for 16-18psi set to run +20 injectors and you should easily be there. Hell, you should be close to 200 with a stone stock set up and a good exhaust without a cat.
03-05-2005, 12:28 AM
My Ride: 99 Cummins
Engine: 5.9
i have a 2.5 and i dynod at 192, running very lean, at 14 psi on a stock t2 turbo and volvo ic. stock 782/swirl head.
220 is probably achievable at the same psi, just getting the fuel a bit closer to where it should be..
You wont want to stop there though.
03-05-2005, 11:54 AM
Originally Posted by adam89shlbydayt
you may suffer lag with the stg 3 wheel, unless the head flows really well.
with a stock head you will need a press. making turbo compared to a flowing turbo.
330 hp has been done on a stock head i believe, though i think they were using race fuel.
You are correct.
I made 337 whp with my 2.2 with a stock long block.
I was using race gas because of the safety factor.
I was using a T3/T4 50 Trim, .63 Exhaust, Stage 3
I would guess you could make about 300 whp with an untouched head.
Just be sure you have the proper cooling.
03-05-2005, 11:58 AM
My Ride: 1987 Shelby GLHS 189
Made 290 with pump gas on a stock head and 22 psi. Car was not tuned well. 1st try with the calibration. Needed lots of work. t3/4 50 with stage II.
Stock turbo I managed over 250whp on pump gas (stock head) at 18psi. Of course that was a 2.2. The 2.5 will make more torque than a 2.2, but I've NEVER seen one make more hp
03-05-2005, 01:30 PM
Originally Posted by TrboVan
You are correct.
the saftey factor was mostly for the stock mahles, wasnt it?
was this on a auto or manual? curious about the stage 3 wheel lag.(with a stock head) thanks
03-05-2005, 01:50 PM
Yes, because I was running the cast pistons.
Automatic.
Lag was not really an issue once I got it sorted out.
It was fun to drive on the street like that.
I do have a video of the lag time somewhere.
-Bryan
03-05-2005, 09:26 PM
#12
My Ride: 88 Shadow
I'm shooting for 300 WHP on 93 at 22 PSI, only I have a stage 1 G head so not only does it flow better it lowers compression to run more boost/more advance on a given octane. Paul from TU said at 22 PSI with a 2.2 G head he can have a no knock retard cal for me.
A ported head is a BIG time plus, I finally sorted things out today and got my car running good on a stock ECU for now. At 13 PSI (and running WAY rich) my car is faster than is was with 21 PSI (at a perfect tune, 1500 EGT's) on a stock swirl head. I also switched to the .63 turbine and my turbo spools FASTER than it did before with the .48 due to the ported head. I blew an IC hose tonight, when I went to fix it (i left the car running) I got air blowing at me at an idle with a super 70 turbo LOL
