Years ago when this car was running before, I had installed a 1G DSM BOV onto it. Everything worked, it blew off and sounded good. I can't remember but I think I had it T'd off of the main vac source on the front of the intake manifold.
Now, when I install this valve and start up the car, the valve partially opens and draws in air. The check engine light comes on. Did the spring somehow weaken? Shouldn't it be shut under idle and cruise vacuum until you close the throttle plate between shifts and see hard vacuum?
With the BOV pipe section removed and a straight piece of pipe from the intercooler to the throttle body, everything works right and no CE light.
I'm flanged for a DSM BOV, so I'd just get another one. I just want to better understand where it *should* go or more importantly where NOT to route the hose, and how it *typically* works. That way I can better jusdge the condition of my own BOV and be more motivated to replace it with another one.
I'm gonna take it off for now, the car acts normal and no CE light with it removed, just running a straight piece o' pipe from IC to TB.
