03-05-2005, 09:02 PM
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
a junkyard. Read over the dodgegarage over and over and over and over to get a feeling.
I run 10psi on my '85 with no ill effects. Without an intercooler, and GOOD gas, this is all I will run...
If you install a new intake and intercooler, you could get to just below cutout (~14psi on a TII). Keep in mind that boost-cutout on an 85 is ONLY 11 psi, and it hurts when it kicks in (still have a sore nose).
A 5th injector can get you a little higher, but over 11 psi with the stock logic module and you'll need to put something in to keep the computer from seeing more than 11 psi from the MAP sensor.
