03-07-2005, 07:12 PM
My Ride: 85 Daytona TurboZ
Engine: 2.2L T2 Modded
try replacing all the vaccume lines and making or buying a better vaccum distributor block. someone on here sells custom ones for like $15.. ask around, and ill try to find the guys name/number...
03-08-2005, 12:36 AM
My Ride: 88 Shelby Z
Engine: 2.2 T2
Port the wastegate hole.
03-09-2005, 12:39 AM
My Ride: 85 GLHT, 87 ShelbyZ
agreed. hole can't vent enough fast enough.
03-09-2005, 04:32 PM
I guess you have tried shimming the can or loosening it up?
What type of exhaust are you running?
Anyhow, you don't port the can nipple, you port the actual wastegate passage on the turbo. On yours, if it is a TIII turbo, you will have to remove it as the passage is built into the turbo housing and not removable.
03-10-2005, 09:24 PM
Originally Posted by blhlfam
I tried a zener diode and it screwed up my ignition timing which cost me a valve when it blew the edge of it off from detonation.
I Just wish someone made a dependable computer calibration for the TIII cars.
I
Ok, we all use Zeners and cut-out raisers with no issues. It doesn't affect your igntion timing. Of course, you have to make sure you have the correct air/fuel and egt's as the computer only has tables for before cut-out. Take it above that and you'll go lean, thats probably why you melted a valve. What guages do you have?
As for cals, www.******************** There custom made to each application.
03-11-2005, 11:27 AM
Actually on the Turbo III it does effect timing, since the zener doesn't allow the computer to see your actual boost levels it adjust the timing for what the zener allows it to see. As I'm sure you know the TIII has no distributor and is completely computer contolled instead of just partially. The turbo II and I, it probably doesn't. But I can tell you for a fact that if your running boost levels above what the Zener allows the computer to see it doesn't know how much to retard the timing. I fought this issue for 6 months until someone on the list told me this. As soon as I removed the zenner i was able to run 13lbs of boost with out detonation, with the zenner at same levels i had major amounts of detonation with very rich signal on the AF ratio.
I was told that you can buy an adjustable zener and allows the computer to see a little higher levels then the non adjustable allows it to see with out getting overboost shutdown but most of the ones I've seen are calibrated for the Turbo I & II ranges of voltage it allows through.
03-11-2005, 12:02 PM
Ahhhhhh, thank you for that little tidbit. I didn't know that. One more piece of info to store in my little brain,
