Old 03-09-2005, 05:53 PM   #1
Exclamation cutout in high gears only HELP!
My Ride: 85 Daytona TurboZ
Engine: 2.2L T2 Modded
ok, so i installed a mBC and tuned it nicely, but it hits cutout in 5th ONLY after i tuned it down. why would i get more boost in 5th than i would in 1st or 2nd??? something doesnt seem right. HELP!!!
Xplizit is offline
Old 03-09-2005, 07:12 PM   #2
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
There's more load on the engine in higher gears so it produces more exhaust. Which of course spins the turbo harder, and produces a little more boost.
Mopar_Nutz is offline
Old 03-09-2005, 07:15 PM   #3
so this is normal then?? it just seemed weird to me.
so i should tune the car so it wont hit cutout in 5th then. my factory boost guage is messed so i cant reliably tell what boost levels im at other than when it hits cutout....
Xplizit is offline
Old 03-09-2005, 07:26 PM   #4
My Ride: td
Yea, it is normal to hit cutout in 5th gear only. You could turn the boost down a little bit, or put a diode/cutout eliminator on it.
Geoff is offline
Old 03-09-2005, 07:54 PM   #5
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
You could also try porting the wastegate if you ever have the turbo off. That should help it to flow a little better and release some of that excess pressure thats building up.
Old 03-09-2005, 08:03 PM   #6
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
You see the creep more in the higher gears because the RPMs are lower and stay lower so the IC has less of a pressure drop.
minimopar is offline
Old 03-09-2005, 10:50 PM   #7
My Ride: 1978 Dodge stepside.
Engine: 318 Turbo Project
Yeah, just happened to me. I was hitting cutout in 4th gear (never got going fast enough to get into 5th gear and boost), and it turned out I was hitting overboost. I retarded my grainger just a 1/2 turn and it seems to work great now.
Michael
MoparFreak is offline
Old 04-18-2005, 05:33 PM   #8
My Ride: 87 Z
Engine: 2.2 (+.040)
still happening to me in 3rd and up...(see post: just an idea...) my dsbc is set at about 16psi so it wont hit 18 when it creeps in 1st and 2nd. in 3rd and up around 4000 it hits 16 holds untill 4500-4600 then all of the sudden it's like a second turbo spooling and then wham! hold on! I'm tired of messing with it, and i've got a few diodes on the way. had to order minimun of 5 so if anyone needs one lemme know... they're 4.7v not 4.3v I've got a S5 cal. and 3bar so I don't know for sure if they'll work on stock or less than S5 cals. From what I've read 4.5v is cutout on stock cals. not positive on that either tho...
87shelbyt2 is offline
Old 04-19-2005, 12:43 PM   #9
I've used 4.7volts Zener diodes on both stock and MP cals. Some stock cals will handle it, especially the 88-89 SMECS. I'm pretty sure the 87 modules won't take a 4.7, as my CSX hits cutout at around 13.5psi.
Jckrieger is offline
Old 04-19-2005, 12:50 PM   #10
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
Why do you need a zener if you have a stage 5 cal and a 3 bar map?
Old 04-20-2005, 01:16 PM   #11
My Ride: 1989 Shadow Es
Engine: 2.5L Intercooled
that's exactly what I was thinking.
CaptTurbo is offline
Old 04-20-2005, 01:31 PM   #12
Don't the stage 5 cals have cutout around 18-20psi? If that's the case, send it back and have it reworked so it doesn't have overboost shutdown anymore. It's simple to change if you have the equipment.
Old 04-25-2005, 01:16 AM   #13
My Ride: 87 Z
Engine: 2.2 (+.040)
I need the zener to keep from cutting out when it creeps... I guess I don't understand what you don't understand... It ramps to 16psi (I set the BC to 16) but then it creeps past it until it hits cutout at 18psi at 4500rpm. I can rev this thing to 7000 all day long in 1st and 2nd with no problem.
ps kreiger I don't want to be without the ecu for months...
Old 04-25-2005, 04:02 AM   #14
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
It would be best to actually get rid of the cutout. If you put the zener in, he cal won't be able to see boost over that 14.xx psi and you won't get any fuel supplied for anything over that.
So either get overboost removed/raised, use a bleed type cutout raiser, or see if you can find a diode that allows enough voltage for the computer to see 18 psi (or close to it)
If I was you I'd get the cal re-done and/or get a bigger wastegate and be done with it
Actress | Gas Suppliers | Compare Mobile Phones | Shares | Child Trust Funds
Page generated in 0.65139 seconds with 13 queries
