Old 03-20-2005, 03:34 AM   #1
Shaft play
How much shaft play is ok.
On a TEO4H Mitsubishi turbo. I know what you were thing.
1980 Camaro Z28,
BW Super T10,
Centerforce Dual friction clutch,
Weiand Stealth 8004,
Holley Street avenger 670 carb,
Crane Energizer 266 Cam,
1970 non-smog heads,
super comp. headers,
flat-top pistons,
Stock crack and rods,
Roller tipped rockers,
1980 350cid truck block
89 Cs daytona turbo 1,
stock but no for long
89Turbo 1 is offline
Old 03-20-2005, 09:39 AM   #2
My Ride: Shelby Lancer #189
Engine: 2.2L TII (stock)
Heh, get outta my head
I've always heard that "some" in/out play is ok, but any side to side play is grounds for rebuild/replacement... Quit grinning...
BigBluOx is offline
Old 03-20-2005, 10:37 AM   #3
My Ride: 1990 Turbo Caravan
Engine: 2.5 obviously
If I remember correctly, the In/Out play on a turbo is the main factor. In/out play is worse than side to side. I think that once the bearing fills with oil, the side to side play is somewhat elminiated. Anyone know forsure??
Raymont is offline
Old 03-20-2005, 10:59 AM   #4
After reading further, Raymont is right, I had it backwards.
And, I need a new turbo since I have both.
BigBluOx is offline
Old 03-20-2005, 12:19 PM   #5
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
My mitsu is tighter than anythng, but my dad's Garrett has a little more side to side play. You think it's because he's running 18psi and I 9psi?
Dave is offline
Old 03-20-2005, 11:56 PM   #6
Show me your g-valve
Lebaronguy2001's Avatar
My Ride: '89Baron, '04Stratus
Images: 19
sounds just like everything in life.....
Lebaronguy2001 is offline
Old 03-20-2005, 11:57 PM   #7
Images: 19
because ive been drinkin....thats why damnit
Old 03-21-2005, 03:52 AM   #8
My Ride: 1987 shelby csx
Engine: 2.4 dohc conversion
To much shaft play will make you go blind.
kedavis is offline
Old 03-21-2005, 06:56 PM   #9
My Ride: 96 neon
Engine: 2.0L
So my Garret T03 only has some side to side play. No in and out. I should be ok for a while? Did not want to rebuild yet, since I do not have the money for what I want.
Jack's Dodge is offline
Old 03-22-2005, 12:46 AM   #10
Images: 19
"some" is kind of vague, but basically....just knwo that that turbo is spinning upwards of 150,000 rpm....if it wiggles much its not good, use your judgement....if someone knows actual numbers maybe they can tell you for sure, but ive always just kinda guessed...you dont want "much" but "some" is ok....im sure that clears things up a lot...
Old 03-22-2005, 07:30 AM   #11
its ok as long as the side to side play does not touch the housing on either side.(comp or turbine) in and out play means the thrust bearing is dieing.
mo' parts is offline
Old 04-08-2005, 04:49 PM   #12
And if the thrust bearing dies you'll start smoking like crazy and then your compressor will have a nice experience with the compressor cover
Jckrieger is offline
Old 04-09-2005, 12:35 AM   #13
Images: 19
that makes it sound almost "cute". a nice expirience...at 150k rpm....lol...thats like a "little oversteer"....into a tree at 90
Old 04-09-2005, 12:55 AM   #14
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Been there, done that. Only it happened to the exhaust turbine at somewhere around 18psi.. Got blades embedded through the housing...
Una is offline
Debt Management | Free Ajax Scripts | Mortgage Calculator | Online Image Resizer | Read Manga Online
