Old 04-06-2005, 05:22 PM   #1
Question Turbo drain's, are mitsu and garrett different?
Title says it all, are the metal pipes differen't?
Old 04-06-2005, 05:24 PM   #2
My Ride: 1987 Shelby Z
1/4: 11.620
good question... I think they might be but can check at home tonight...
B.A.P. is offline
Old 04-06-2005, 06:07 PM   #3
Show me your g-valve
Lebaronguy2001's Avatar
My Ride: '89Baron, '04Stratus
Images: 19
the gaskets are different.....so i would assume there must be "some" difference....
Lebaronguy2001 is offline
Old 04-06-2005, 09:16 PM   #4
als
My Ride: 89 caravan es t1
Engine: 2.2 garett/ 3 inch e
yes they are just like the turbo / mish is smaller 10 mm bolt heads/ garett 13 mm head bolts and a bigger tube. and i,v found that there a diff. in length in the drain tube to the block when installing a older t1 garett converted to t2 with a t2 exth. manifold/ takes a longer hose 1/2 longer i think ALS
als is offline
Old 04-06-2005, 09:16 PM   #5
the pipes are different. The bend is different and the place where it bolts on.
1985ShlbyChrger is offline
Old 04-06-2005, 09:33 PM   #6
Thanks guys, I had a feeling, wasn't sure!
Old 04-08-2005, 11:24 PM   #7
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
The bolt pattern is different as well
Mopar_Nutz is offline
Watch Anime Online | Loans | Remortgages | Current Accounts | Mortgages
Page generated in 0.32624 seconds with 13 queries
