04-21-2005, 11:56 PM
My Ride: Dodge Omni GLH clone
Engine: 2.2 inline 4
After you bother with all of that, youmight reach the power levels that you could by running a regular 2.5 T motor at a little higher than stock boost lenvels thru and intercooler, from a turbo 2.5 donor car. Swap in a motor, trans, and wiring and computer woudl be alot easier than the fabrication you are going to be doing. Not to mention that you will be pulling that broken motor out soon anyhow, seeing as the pistons and rods, and clutch aren't intended for turbo abuse. You will blow up the NA motor with boost.
