Old 04-30-2005, 11:25 PM   #16
My Ride: GLHS Charger
Zip ties, as the hose should fit kinda snug in the first place.
MVaughn is offline
Old 05-03-2005, 09:30 AM   #17
My Ride: 1986 GLHS #065
Engine: 535hpAluminumLongRod
1/4: 11.921
Images: 19
clothes pins???? mabey???
SUPER60omni is offline
Old 05-03-2005, 09:31 AM   #18
1/4: 11.921
Images: 19
Ha Ha no my car requires zip ties on everything @ 32psi
Old 05-26-2005, 04:53 PM   #19
My Ride: 67Ranchero, 85 GLHT
Engine: 289CI, 2.2 T2 cnvrsn
Originally Posted by tonyz2897
I use tie wire. Just cut a piece of wire about 3" long and bend it into a u around your finger. Now put it around the hose where you normally would a clamp or zip tie and cross the ends. Then simply take a pair of pliers and twist a few times until it binds down tight on the hose. Cut off the excess and you're done.
I've got every vac. connection on my car done like this and have had 0 problems with them blowing apart even at 27 psi. Just be careful not to bind the wire down so tight that it cuts the hose.
The only disadvantage I've found to doing it this way is that ends of the wire are sharp after you cut them off and it's pretty easy to get scratched up if you have to work around them.
HTH,
Tony
When a zip ties has been clipped off tight, and a bare hand passes by, it will draw blood too! For me, wire twisted and curled back into itself with a needle nose is best. Or, still better - find the little 3 prong spring clips that don't twist over and fight you when you grab em with pliers - reusable.
johnl is offline
Old 05-26-2005, 05:00 PM   #20
My Ride: mostly mopar
Ive found that trimming the zip tie with rounded ended nail clippers helps best. I should own stock in a zip tie company as its my first mod when getting a new car.
BLUEBALL is offline
Old 05-27-2005, 02:37 AM   #21
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
How do the zip ties hold up heatwise?
John B is offline
Old 05-27-2005, 10:55 AM   #22
I run them on all the vac connections in my rides, and they hold up fine. I would immaginge that if the hose will hold up, the zip ties will too.
OmniGuy123 is offline
Old 05-27-2005, 12:41 PM   #23
Depending on the heat or proximity to a big heat source, IE right on top of the exhaust manifold, they can do get brittle with time, how long, who knows? Just give them a tug once in a while!
IT247 Computer Hardware | Servidores dedicados | Ringtones | Electricity Suppliers | Child Trust Funds
Page generated in 0.35101 seconds with 13 queries
