Old 04-26-2005, 10:22 AM   #1
zip ties or hose clamps??
My Ride: plymouth DUSTER
Engine: 2.2 power
i was going to use zip ties but i dont know if it would be really tight. i am going to do about 12 psi of boost
so what do you dudes think zip ties or hose clamps??
ps manifond to wastgate hoses
turboduster is offline
Old 04-26-2005, 10:24 AM   #2
My Ride: 94 Ford Lightning
Engine: 351W v8
I actually don't use anything to start. If something blows off, I'd stick a zip tie on, but if you have decent hoses, they should nessle over that barb and stay there.
Subliminal is offline
Old 04-26-2005, 10:29 AM   #3
yeah, they should, but zip ties are extra security to make sure you don't have to pull over in front of your friends after racing that mustang. zip ties work well enough.
tony
macncheese is offline
Old 04-26-2005, 01:25 PM   #4
My Ride: '88 Sundance
Engine: '89 2.5 TI
I use tie wire. Just cut a piece of wire about 3" long and bend it into a u around your finger. Now put it around the hose where you normally would a clamp or zip tie and cross the ends. Then simply take a pair of pliers and twist a few times until it binds down tight on the hose. Cut off the excess and you're done.
I've got every vac. connection on my car done like this and have had 0 problems with them blowing apart even at 27 psi. Just be careful not to bind the wire down so tight that it cuts the hose.
The only disadvantage I've found to doing it this way is that ends of the wire are sharp after you cut them off and it's pretty easy to get scratched up if you have to work around them.
HTH,
Tony
tonyz2897 is offline
Old 04-26-2005, 01:46 PM   #5
My Ride: 84 rampage
Engine: 2.2L T3
bah, those aren't good hoses, you're just not running enough boost
Mike Radowski is offline
Old 04-26-2005, 09:08 PM   #6
Engine: 2.2 power
ya one of them blow off then my friend was trying to drive stick
Old 04-26-2005, 10:45 PM   #7
I found out the other day that zip ties are pretty much required for my setup above 20 PSI.
OmniGuy123 is offline
Old 04-26-2005, 10:49 PM   #8
My Ride: 88 sundance
eeewwww, i hate zipties, at least hose clamps are lik .50 each
jdawg is offline
Old 04-27-2005, 08:46 AM   #9
Engine: 351W v8
Old 04-29-2005, 12:10 AM   #10
I use hose clamps on the 3/8'' main vacuum lines and zip ties for the smaller lines. This setup has been tested at 25psi
Jckrieger is offline
Old 04-29-2005, 04:55 AM   #11
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Ditto. As soon as I started pushing 19-20 psi in my Lancer, I was blowing vacuum lines underhood and under the dash. I've bought some small zip ties from the hardware store and haven't blown one off since.
iTurbo is offline
Old 04-30-2005, 12:22 AM   #12
Engine: 2.2 power
d@mn i am just ran 12psi and blown one( bad hose i think )
Old 04-30-2005, 02:22 AM   #13
My Ride: 91 R/T-66 pontiac
Engine: T3 2.2/ 4bbl 389BB
1/4: 13.940
i have never had a problem with vac lines with anything less than 16 psi, as long as they are the correct size you shouldnt either
glht_omni is offline
Old 04-30-2005, 07:09 AM   #14
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
I use zip ties.
Im waiting for someone to say they use duct-tape. "It fixes all of life's little problems."
Dave is offline
Old 04-30-2005, 11:20 PM   #15
Engine: 2.2 power
lol
Credit Check | Venta de libro | Loans | Credit Card | Personal Loans
Page generated in 0.47441 seconds with 13 queries
