Old 05-08-2005, 09:46 PM   #1
2-5 psi max boost?
I have just built a new 2.5 Turbo engine with a FME2 turbo .63 A/R exhaust housing. My problem seems to be that the most boost im able to push at full throttle in any gear is about 2-5 pounds.. most times all i see is 0psi. Engine pulls 19 inches of vacuum at idle. i have the wastegate actuator adjusted as short as possible and have even disconnected the hose from the actuator and no difference.
Could a leak to atmosphere in the induction system after the turbo cause this condition? I have no idle problems at all.
Any ideas are appreciated.. im lost.
Tryte is offline
Old 05-08-2005, 09:54 PM   #2
I assume that you double checked to make sure that the WG arm is still attached to the flapper. It would take a pretty large leak in the IC piping for you not to get any boost out of the turbo, but I guess it could happen. Pressure test it if you can. Check out the pictures of the testers that I made here How I pressure tested my ICs
They revealed a couple small leaks in my system that I did not know about.
OmniGuy123 is offline
Old 05-09-2005, 08:58 PM   #3
I am actually bypassing the intercooler right now for that very reason. I am running the turbo straight into the TB with one hose, to eliminate the chance of leakage. As for the WG actuator. I had it off last nite to adjust it in and i definately reinstalled it on the flap valve.
Thanks
Tryte is offline
Old 05-09-2005, 11:38 PM   #4
Well if it runs alright, then it should not be any crazy timing issue. since you obviously dont have an IC leak that is ruled out. brand new turbo that is not blowing smoke.
You said that the WG arm is adjusted as short as it will go. could it be possible that the arm is inherently too long even at the shortest setting? If you have acess to another WGA, I would try to slip it on and give her a go.
Old 05-09-2005, 11:51 PM   #5
I just talked to FM and they had said that the WG can arm may need to be cut shorter to allow more adjustment inwards. I will try that and let u know.
Tryte is offline
Old 05-10-2005, 01:13 AM   #6
My Ride: '88 Lancer Shelby
ive had the same type of issue.. i had cut the power to the computer, and it took the smec 60 or so kms [40miles] before it gave me 12 psi..
bernard
gti_7 is offline
Old 05-13-2005, 10:46 PM   #7
I cut the wastegate actuator arm to allow me to adjust it even tighter. gained maybe 2-3 more pounds.. max.. still note getting anything more than 5psi. I have an original cat on there rite now that rattling.. Do you think its possible that its blocked up inside and the backpressure is so excessive in the exhaust that its keeping the turbo from spooling up? Any suggestions here guys.. i just want my car to have boost again!
Tryte is offline
Old 05-14-2005, 08:57 AM   #8
I would try to wire the WG flapper closed. so that you know for sure that it is the WG or not. I guess it could be the cat, but every time I have heard of that happening the car ran like crap pretty much all the time.
Old 05-14-2005, 11:32 AM   #9
You already answered your own question. The cat internals are loose and causing the backpressure which is giving you little or no boost. Drop the DP and go for a drive. Becareful as you might hit 14 psi or so!
Old 05-18-2005, 12:43 AM   #10
Just wanted to let you guys no i cut out the cat and sure enough it was all clogged up inside. Massive overboost from the car now. Going to readjust the wastegate actuator longer and see if i can get the boost down. Thanks for everyones advice.
Tryte is offline
Old 05-18-2005, 08:28 PM   #11
Glad to see that you figured it out.
Honda CBR600RR | Credit Card | Loans | Adverse Credit Remortgage | Web Development
Page generated in 0.38531 seconds with 13 queries
