Old 05-18-2005, 10:58 PM   #1
external wastegate
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2 T2
how do you determine what spring pressure is needed for the gate? when they refer to 7,8,14 psi does that mean it takes that much to make it work?
overboostperformance is offline
Old 05-19-2005, 10:07 AM   #2
usually it means the spring will set the boost at the given number. that would be the boost level you would get by just hooking the reference line straight to the intake. adjust it up from there with a grainger valve.
xrattiracer is offline
Old 05-20-2005, 10:46 AM   #3
My Ride: 1989 Shadow Es
Engine: 2.5L Intercooled
exactly.....basically, just don't use the 14 if you ever planning on running less than 14psi . I use a 7, and let the boost controller do the rest, just like X said... It's nice to be able to detune the car quickly and easily like that...keep an extra piece of vaccum line cut to size....pop off the line with the MBC on it and pop on the new line straight to the gate, and voila....15 second 7psi "valet mode"
CaptTurbo is offline
Old 05-20-2005, 12:04 PM   #4
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
Originally Posted by CaptTurbo
. I use a 7, and let the boost controller do the rest, just like X said... .
What do you mean you use a 7? I dont know what that is, lol
Dave is offline
Old 05-20-2005, 12:04 PM   #5
oops, double post, sorry.
Dave is offline
Old 05-20-2005, 12:26 PM   #6
he used a seven pound spring in the wastegate.
turbodave/neon is offline
Old 05-20-2005, 01:14 PM   #7
^Thank you...yes.
Old 05-22-2005, 10:41 AM   #8
Engine: 2.2 T2
Thanks for the info. i had a feeling thats what it was but wanted to be positive.
Loans | Loans | Company Reports | Mobile Phone | Fantasy Football Cheats
Page generated in 0.35962 seconds with 13 queries
