Old 05-21-2005, 02:20 PM   #1
A TU 3" SV fit on a Ford .63 housing?
My Ride: 88 Daytona Shelby Z
Will a Chrysler swing valve (3" TU) bolt up to a .63 Ford exhaust housing?
scott_s is offline
Old 05-21-2005, 02:36 PM   #2
No!
Old 05-21-2005, 02:38 PM   #3
My Ride: 88 Shadow
Feedback: (7)
Different bolt pattern.
moparzrule is offline
Old 05-21-2005, 02:39 PM   #4
My Ride: 88 Shadow
Feedback: (7)
My gosh Simon you beat me again, go back to work!
Old 05-21-2005, 04:01 PM   #5
Thanks for the succinct answer.
scott_s is offline
Old 05-21-2005, 04:22 PM   #6
My Ride: 87 Shelby Charger
Engine: 2.2l 135CI
Are we sure they are a different bolt pattern? The only bolt pattern that I thought was different was the mounting flange, which in the case of the Ford would be a standard T3 pattern. I believe the SV has 5 bolts just like the Chrysler.
I could be wrong, but seems like that is was I recall.
mw6886 is offline
Old 05-21-2005, 05:17 PM   #7
Chrysler Mitsu have there own bolt pattern, as does Chrysler Garrett. Ford SV's has another bolt pattern. I had to buy a Ford SV for my T3 turbine housing and an elbow so I could use the stock DP from FM!
Old 05-21-2005, 07:06 PM   #8
My Ride: 86 GLH-T 2.5 W/A568
Engine: 2.5 T3T4 hybrid
I wish I knew that, I got one here I cannot use.
TheGinMill is offline
Old 05-21-2005, 07:09 PM   #9
fyi the ford stuff isnt ford specific, they just ordered a standard T3 from garrett, so most aftermarket non-brand specific parts should fit it.
xrattiracer is offline
Old 05-21-2005, 07:29 PM   #10
Sure you can, you by a Ford/Universal SV and then the elbow from FM. Thats what I am and the R/T owners do!
Old 05-21-2005, 10:07 PM   #11
Engine: 2.2l 135CI
I do not believe the the Chrysler Garrett has its own SV bolt pattern. It is just a standard T3 5 bolt pattern. I do believe the the Mitsu and the Garrett are not interchageable, that is obvious. But the SV on the Ford T3 and the Chrysler T3 should both be 5 bolt and the same pattern.
mw6886 is offline
Old 05-21-2005, 10:16 PM   #12
My Ride: 88 Shadow
Feedback: (7)
They are both 5 bolt but different bolt patterns.
Old 05-25-2005, 01:49 PM   #13
Speaking of the Forward Motion Ford/Universal elbow. Does anyone know if it would work with a TBI header? Assumeing of course that the turbo has the universal ford 5 bolt pattern.
landon
WLKIVETT is offline
Old 05-25-2005, 05:12 PM   #14
My Ride: 88 Shadow
Feedback: (7)
^ It should still work fine, actually now that I think about it a ford SV might work better than ours fro a TBI header because of firewall clearance.
Mortgages | Credit Cards UK | Mortgage | Gas Suppliers | Best Credit Cards
Page generated in 0.42712 seconds with 13 queries
