Old 05-26-2005, 02:42 PM   #16
My Ride: 88 Daytona Shelby Z
Chris (TU), was very nice and explained to me how to test the can. I will do that when I am able.
scott_s is offline
Old 05-26-2005, 03:02 PM   #17
Originally Posted by Marcus86GLHS
"Could be a leak in the wastegate actuator diaphragm."
yes.
boost creep is most usually related to a weak MAP signal reaching the wastegate can, due to a leak in the line, or the can itself. run a new line to the wastegate can, make sure all connections are tight and leak-free.
The lines are newish silcone ones. The go from the wastegate to the g-valve to the TB nipple. I will check the connections.
scott_s is offline
Old 05-26-2005, 04:00 PM   #18
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
Originally Posted by Putter
Enlarging a wastegate hole bigger than necessary to mask the problem of a mis-adjusted wastegate actuator is both more work than necessary, and not fixing the root cause.
But sometimes the said hole just cant flow enough... so you port it.
I had this problem on the k car when I first fired it up.... crept like crazy with the arm totally open. I ported the hole and the creeping stopped. no other changes.
Brian
Aries_Turbo is offline
Old 05-27-2005, 01:23 AM   #19
My Ride: '87 Omni
Engine: Dodge 2.2
I know you can overwhelm them, but from what he said, I don't think he was to that point yet.
I've ported turbo wastegates before...a twin turbo rx7 comes to mind...
Putter is offline
Old 05-27-2005, 10:16 AM   #20
Engine: 2.5L T2
gotcha. i dunno... it sounds like "hole too small" creep to me... that or the diaphram is torn or leaking a little. he could unhook the wastagate totally and open the arm the whole way with a spring and drive around... if the boost rises to cutout, he has creep. this is what my issue was. i wouldnt get boost till 3rd and 4th but it would crank the whole way up to 18psi lol.
Brian
Old 05-27-2005, 11:32 PM   #21
One of my lines to the g-valve was a little loose. I tightened it up. Testing so far still show creep. I my set boost in all gears and then some
scott_s is offline
Old 05-28-2005, 07:39 AM   #22
als
My Ride: 89 caravan es t1
Engine: 2.2 garett/ 3 inch e
do you have the restickter in the vac line / don,t you just change the hole size ? like 30 up till 50 on the hole size.ALS
als is offline
Christmas Gifts | eHarmony Coupon | WoW Gold | Debt Consolidation | Free Ringtones
Page generated in 0.34635 seconds with 13 queries
