06-22-2005, 06:58 PM
My Ride: 89, 94 LeBaron,89 TC
Engine: 2.5 T-1, 2.2 T2,3.0
What year ? 88's and 89's run the pressure line over to the boost solenoid on the pass. inner fender. The solenoid is normally vented to the atmosphere, when it closes boost pressure is fed to the wategate diaphragm opening the wastegate and limiting boost. The plastic lines become very brittle especially behind the valve cover. Be vary careful or have some plastic tubing or hose handy. If you snap any it will probably be several !
