06-23-2005, 10:51 PM
My Ride: Omni
Engine: 2.2 liter 16V hybrid
Originally Posted by Stevien1
Sounds like it could be a weak wastegate actuator spring inside of the can. The Mitsu turbo is so restrictive that in the higher gears (when there is more load on the motor), the pressure in the turbine is actually forcing the wastegate open.
A boost controller, like the Granger valve, can only set boost as high as the wastegate actuator can allow. So cranking it up will have little or no effect in this situation.
You can try shimming the existing actuator away from the compressor cover (two headbolt washers work great) in and effort to increase spring tension. However, by shortening the travel of the actuator arm, it'll be more prone to boost creap.
Finding a low mileage wastegate actuator with a strong spring is probably the best thing to do (aside of swapping in a REAL turbo). You could experiment with sending vaccum to the actuator to help hold it shut.....
-Chuck James
Great reply Chuck, i will take a look on that tomorow. :-)
