Old 07-04-2005, 12:53 PM   #1
Intercooler into van mod
My Ride: 89 Voyager
Engine: 2.5L T1
NOW HOW do u TD van guys get those big intercoolers into the front of the caravan/voyager?? I haveremoved the condenser/Compressor, and plan to remove the fan for the condenser but I still have the radiator on the left side and the trans cooler behind that.. where do u guys find room to install the big IC'es.. I personally was looking for a T2 IC and just put it on the side where the condensor was
Dave
turboGTC is offline
Old 07-04-2005, 01:59 PM   #2
My Ride: 86 GLH-T 2.5 W/A568
Engine: 2.5 T3T4 hybrid
Sawsall. Remove a ton of material.
TheGinMill is offline
Old 07-04-2005, 03:06 PM   #3
wow simply awesome
is that a cumins diesel ic?
ezspool is offline
Old 07-04-2005, 03:11 PM   #4
My Ride: 89 Voyager
Engine: 2.5L T1
now with the small turbo these car have wontthat cause a bunch of pressure drop???
also how sturdy is the car now that u chopped all of that out?
Dave
turboGTC is offline
Old 07-04-2005, 03:54 PM   #5
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Dave
The improved performance of the intercooler vastly offsets any minor problems being insanely large might cause. It's been proven over and over on TD's.. And big intercoolers take far longer to heat soak. Handy when your Mitsu turbo is throwing out 400+F air.. hehehe
And how sturdy were these cars to begin with? heh, really, it's on the far side of the crumple zone, that whole part of the car is designed to crush easily, I don't think cutting some very thin gauge sheetmetal out of there will cause any harm. And if that intercooler is bolted in well, it just might be more structural than the sheetmetal it replaced was.
Una is offline
Old 07-04-2005, 04:50 PM   #6
My Ride: 1994 Caravan turbo!
Images: 4
Originally Posted by ezspool
wow simply awesome
That picture was a Ford Powerstroke intercooler.
big_P is offline
Old 07-04-2005, 05:46 PM   #7
My Ride: 89 Voyager
Engine: 2.5L T1
gottcha
we shall see I am putting in a aluminum racing radiator in the near future not sure what kinda space I will have then
Dave
turboGTC is offline
Old 07-06-2005, 09:07 PM   #8
My Ride: 89 Acclaim LE turbo
Engine: 2.5L SOHC
A Sawzall is your friend.
now with the small turbo these car have wont that cause a bunch of pressure drop???
A PowerStroke intercooler flows about 450 cfm at the (industry standard) 1.5 psi pressure drop. By comparison, a single stock Dodge 8v intercooler flows about 325 cfm at the same pressure drop. So while the PS is better than a single Dodge core, it's not as good as a double core intercooler.
BTW: intercooler pressure drop is a function of airflow restriction inside the intercooler. Total core volume in and of itself is not a direct indicator of potential flow loss through the core.
TurboMinivan is offline
Old 07-07-2005, 06:57 PM   #9
My Ride: 89 Caravan
But even though the two core Dodge cooler would flow more, it wouldnt cool as well as a Powerstroke correct?
My96z is offline
Old 07-07-2005, 11:20 PM   #10
well think of it this way
the powerstroke ic havs a larger area to cool ie the whole front of the f@#$ing van, yet blocks flow to the radiator, the smaller double core would get less flow area but would allow the radiator to cool better, i'd go with the powerstroke thoughi bet it will cool much better
ezspool is offline
Old 07-07-2005, 11:37 PM   #11
My Ride: 89 Caravan LE Turbo
My Probe IC to one side did just fine here in Arizona and I kept the AC intact!
AZTurboMini is offline
Old 07-08-2005, 09:10 AM   #12
My Ride: 89 Voyager
Engine: 2.5L T1
for a daily driver family ride the radiator is my main concern more then th eIC..
also curious I saw a flange adapter for a T1 to T2 conversion.. what the heck is that for???
this is what I am refering too
http://********************/shop/index.php?cPath=111_114
Dave
turboGTC is offline
Homeowner Loans | Bankruptcy | Xbox Mod Chip | Debt Consolidation | Virtual Private Server
Page generated in 0.41560 seconds with 13 queries
