10-17-2006, 07:37 PM
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I've done this on about 10 engines, all Chrysler 4, 6, and 8 cylinders, 1970-1989 model years.
Sandpaper the freeze plug hole to make sure it is clean.
Coat back side of freeze plug with a thin layer of RTV.
Pound freeze plug into hole, making sure edge of freeze plug is BELOW the edge of the machined hole surface in the block. I've seen lots of experts install plugs flush with the block surface, and it's no wonder that the plugs pop out! The edge of the plug flange has to be able to bite into the flat metal. If you install it flush with the block surface, that crucial edge isn't grabbing anything, and the taper of the edge surface is already trying to pop the plug out!
Then once the freeze plug is properly installed, I give the front side and especially the edges a good heavy layer of RTV to "glue" (kind of) it in place and seal the metal plug from rust.
Never had a plug come loose or leak on me yet.
