11-06-2006, 10:33 PM
My Ride: No slicks Omni
No chance the flexplate bolts are loose is there? Regardless if it
is an auto remove the 4 flexbolts and fire it up and listen. Cracked
flexplates are common on these cars as most domestic low quality
pieces of iron built from old Toyotas.
11-09-2006, 08:26 PM
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2 T2
+1 ^
i have also had the wrist pins clips come out and make a rattle under load but under cruise nada . sounds like rocks in a coffee can was very hard to diag.
Norm
11-11-2006, 11:40 AM
If it is a manual tranny, The same thing applies. I have a very good friend that had this happen to with a 85 GLHT while under warranty. He also is in the auto industry, and thought, crap the bottom end is letting loose. The mechanics agreed. The motor was torn down like three times trying to find out why the rods where making so much noise. The car had like 2000 miles on it. A newbie mechanic at the dealership saw all the veterans scratching their heads and talking about it over lunch/ breaks etc. The newbie said immediately, that sounds like the flywheel bolts are loose. We see that occasionally at the service station garage where I used to work. Of course they laughed and rolled their eyes at the newbie. Well after tearing it apart for the third time, out of desparation, one of the mechanics pulled the tranny and found the flywheel bolts had started to oblong the flywheel bolt holes. In the meantime, a NEW shortblock had been ordered from Chrysler. Well, the veterans learned something new that day, and the newbie gained some acceptance at the dealership. Most of all, the my friend finally got to enjoy his GLHT. Lesson learned!
11-17-2006, 09:24 AM
Authorized TD Vendor
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
If the Ross is anything like a Venolia piston, you get a Holy Crap look on your face when you first start it. It does sound like a rod knock but should gradually get quiet after the engine warms. If it doesnt the pistons are way to loose or something else is wrong.
Wallace
91 Spirit R/T
11.686@120.89 mph
11-17-2006, 12:01 PM
I have used Ross pistons in close to a dozen 2.2 applications and they are never noisy at start up. I agree with Wallace, that you may have way too much piston to wall. Since Ross doesn't have a stocked piston for our application, they are all custom made, your engine builder must have given Ross some specs for the application. Ask your builder what piston to wall clearance they used. Should have been .004-.0045 for a turbo application. Ross pistons don't need the clearance that Venolia pistons do. If they did run like .008-.010 clearance (top of skirt) that Venolia suggests, yeah they're going to be pretty noisy. The instructions that Ross sends with the pistons are quite clear on this and what ring gaps they recommend. Ross is in the camp that wants to see larger second ring gap than the top ring.
I stopped using Ross only because they take WAY too long for turn around time. The last set I ordered I gave up after a 3.5 month wait. Diamond pistons had my custom pistons in hand in 2.5 weeks. Been using them ever since.
11-18-2006, 04:28 PM
My Ride: 89' Daytona Shelby
Engine: 2.2L TII S60 kit
Dont get to comfortable thinking its only the forged pistons heating up. When i finished putting my rebuild together this summer, I had some tapping that i figured was only my Wisecos heating up. Turns out all the cam caps were finger tight or less! Dad saved my bacon on that one.
11-23-2006, 01:50 PM
My Ride: 1986 GLHS
Engine: 2.2 turbo
What about the intermediate shaft bearings? Could they cause such a noise?
01-07-2007, 07:33 PM
Hybrid Booster
My Ride: 86 GLH OMNI 30psi
Engine: 2.2 liter
1/4: 12.453
Originally Posted by TurboDeano
Doesnt sound like a funny rattle to me.....
Pull the head off and check it out.
I have run across
loose cam gear bolt, a stock cam in an oversized cam journel that dodge did from the factory, I did my first motor with .010 clearence and it rattled when cold, and the the lose converter bolts sounds real loud!  Oh and if oversized wrist pins you will find problems, or at least 2 sets my buddy installed in his car..
