03-15-2007, 07:02 AM
#16
Originally Posted by tryingbe
No, not all CB 2.2L pan are the same. Some 2.2L came with balance shaft, some 2.2L didn't.
So, to sum up: CB pan and pick up with balance shaft are all the same; CB pan and pick up with NO balance shaft are all the same.
No, this isn't true and it came up when I was developing the windage tray patterns. The late CB pans had slightly more access room on the flywheel end -- presumably to make servicing easier.
Even if you had the pans side by side you might not see this. I run into this stuff all the time (or am told about it).
I am working on windage control for the Toyota 2zz at present (Shhhh). They moved the pickup tube over from the 1zz by 1.5mm. Hot performance tip: Use the 1zz pan and get out the die grinder.
