10-13-2007, 07:38 AM
Re: Intermediate Shaft In/Out Play
My Ride: 1990 Dodge Caravan
Engine: 2.5 T1 Intercooled
The gasket theory makes sense. I found a bunch of pieces of broken up gasket material caught in the oil pickup screen. I swapped the pickup for another one, but couldn’t think of where this gasket would be coming from. I bet the gasket broke up opening up the clearance on the shaft. How do I get it apart to check? Is the retainer bolt in or press in? What if anything should I do to correct it?
Engine otherwise looks good. Very little wear on the cam, lots of crosshatching in the bores. All the rod ends are tight on the crank, no side to side play. I have the balance shafts out, the oil feed to them plugged and now I’m working on cleaning parts and re assembling. I think it will be fine once I get things back together.
