04-03-2003, 11:10 PM
#14
Static balancing is equalizing the weight of parts such as pistons and rods. Lighter pistons make more torque so its good we have to remove weight rather than add it. You want to remove weight from the heavy pistons to make them equal to the lightest. Typically you grind some aluminum from the pin boss. Rods are a little more difficult as the big and small end should be balanced seperately. You can grind some metal from the top of the rod and the bottom of the rod cap. Often there are flat spots at both locations refered to as balance pads where you remove metal. Dynamic balancing is done on a machine that spins the crankshaft. After the static balancing is done bob weights that simulate the weight of the pistons, rods, pins etc. and even the estimated oil are attached to the crank and metal is added or removed from the crank, flywheel or harmonic balancer. This is only done on V engines as inline engines are in a state of natural balance. As in everything there are probably exceptions to this but none that apply to the Trans Four.
Thanks
Randy
