04-18-2008, 12:40 PM
Re: common block questions..
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Sure use the 89 common block. You'll just have to drill out the oil return tube hole + cross drill the cylinder surface and it will be the same as a turbo block. The coolant return hole is already there, just plugged with a bolt. You can run the 2.5 crank if you like just get stronger rods and pistons, or you can get a 2.2 crank, rods and pistons if you want to go 2.2
