Old 03-28-2008, 07:02 PM   #1
bolting hole locations between CB and nonCB?
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
are the exterior bolt hole locations the same between common block and non common block?
bluneon is offline
Old 03-28-2008, 07:54 PM   #2
Re: bolting hole locations between CB and nonCB?
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
Feedback: (29)
Images: 166
common block has a couple less holes(fuel pump block off) other then that they are the same externally.
-Clayton Dennis ~ Forum Admin
1987 Shelby CSX #674
1985 Dodge Omni GLH
moparfwdsleeper is offline
Old 04-03-2008, 12:06 PM   #3
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
Don't forget if its a TBI block then it doesn't have a turbo oil drain back...Which you can easily add to the block.
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
86trbolancer is offline
Free Ringtone | Mobile Phones | Personal Loans | Hotel Las Vegas | eBay
Page generated in 0.24465 seconds with 13 queries
