Old 05-11-2008, 06:01 PM   #16
Re: MP or Cometic Head Gasket Size?
My Ride: 1989 Lebaron Coupe
Engine: 2.5 Turbo II
Originally Posted by The Pope View Post
The .051 is half way between stock and MP gasket. I would reduce base timing to 12-14 and advance the cam 2-4 degrees.
So let it be written, so let it be done. Thanks
Miss89baron is offline
Old 05-11-2008, 07:07 PM   #17
My Ride: 85ShChgr, 91SprtR/T
Miss89baron, I am still curious.
Are you having any chamber work done to your heads? IE: unshrouding the valves, or anything like that?
Screamin4banger is offline
Old 05-11-2008, 10:41 PM   #18
The valves are being unshrouded / back cut on the intake and exhaust. The head porting includes chamber work, bowl cuts and port matching. I'm not sure how extensive as this Baron is a weekend driver with occasional track test. Trying to get in the 325-350 whp range and maintain drivability.
Online Loans | Loans | Credit Card | Mortgage | Mortgages
Page generated in 0.26741 seconds with 13 queries
