Old 05-19-2008, 12:20 PM   #1
M10 stud option?
My Ride: 85 GLHT
Is there a set of 10mm head studs available for some other application that might work? Or, am I just missing a resource for the old 2.2?
saxhouse is offline
Old 05-19-2008, 01:22 PM   #2
Re: M10 stud option?
ARP still had them last time I checked. but I'd go with 11mm and have the holes drilled and tapped by a machine shop to ensure they are straight and true. On my old blocks, I set up a mill with a drill then changed to an 11mm tap with a clutch drive on the mill (same unit I used to convert GM heads to screw in studs instead of the pressed in rocker studs)
22dodge is offline
Old 05-19-2008, 02:17 PM   #3
My Ride: 85 GLHT
Thanks for the recommendation. I plan to have the engine on the stand drilled out, but the one in the car needs it now and the head is getting shaved as we speak. Tech inspection next week, so time is key.
saxhouse is offline
Internet Advertising | Remortgages | Personal Loans | Loans | Cheap LCD TV
Page generated in 0.35745 seconds with 13 queries
