Old 04-13-2003, 10:32 PM   #1
Soft plugs????
ANTI BOWTIE.
jonny mopar's Avatar
My Ride: 04 2500 cummins
Engine: 5.9 I6
What is the easiest way to change the soft plug With the motor in the car?? It is the one that is behind the starter. Will it hurt anything If it falls down inside the block??
________________________________
Jon Clements
MostOutrageousPowerAndRev!!!!!!!!!!!!!!!!
04 dodge 2500 qad cab short box cummins 6sp 6" lift quadzilla X2. My DD.
03 VW beetle TDI 5sp G/F's DD
07 honda crf 450x. SOON to be Street legal and my DD
82 dodge short box step side 2wd, mild 318 with shift kit. NICE truck for sale
78 dodge power wagon short box step side 400 BB 4sp 4x4.
Mopar or No car!!
jonny mopar is offline
Old 04-13-2003, 10:57 PM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
You mean, frost plugs.
Drain the coolant, not just the rad, but also disconnect the coolant return line from the turbo at the block. Remove the starter & drill a hole in the frost plug so you can self tap a screw/bolt in it & then you can pull it out.
When installing the new one, your suppose to apply something like RTV silicone(???) around it, then tap it in flush.
crazy1eye is offline
Old 04-13-2003, 11:12 PM   #3
ANTI BOWTIE.
Engine: 5.9 I6
Thanks alot. Sounds easy, I'm just worried bout the room i have to work with well i am under there LOL
Jon Clements
Mopar or No car!!
Old 04-21-2003, 05:36 AM   #4
What I did on my cars was carefully tap one side w/ a hammer and screwdriver until it turned sideways in the hole, then pull it out w/ pliers. Did it on the GLH, my brother's Dakota, and my rooomate's Thunderbird to install block heaters.
On that note, one those block heaters are installed, can they be removed and re-installed? Or can you purchase just the heater plug w/o the cord?
supercrackerbox is offline
Old 04-21-2003, 01:10 PM   #5
ANTI BOWTIE.
Engine: 5.9 I6
Well i found out it wasnt a soft plug it was a bolt that was missing in the back off the exhaust manny, THat was even harder to do them the soft plug. Thanks alot for the help though
Jon Clements
Mopar or No car!!
Mortgage Calculator | Personal Loans | Credit Card | Ugg Boots | Free Myspace Layouts
Page generated in 0.45419 seconds with 13 queries
