Old 07-01-2008, 05:27 PM   #16
Re: Rod Bearing Missing with piston removal!!!!
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
Originally Posted by bsbllfit7 View Post
hey everyone i just started taking apart my block today and noticed that the wearings were excessively worn, it looks like from oil starvation. On the number 3 piston there was no rod bearing on the upper or lower half of the rod or cap!!!! Could this have happened from just running the engine or did the re**** that rebuilt this last forget to put on bearings??? I have a hard time believing that someone could be that stupid
He clearly stated "rod bearing". Shoulda' heard that even with open exhaust.
Stereo might possibly have drowned it out , but I don't know.
ol"blue is offline
Old 07-01-2008, 05:32 PM   #17
My Ride: 1988 shelby z
im positive it is a rod bearing and i ran it for o gosh prolly 2 or 3 months with no problems tell the end. I havent even taken the caps off for the main bearings to be exposed so i know its the rod bearing, i just cant think of where it could have gone too and i know there should have been a knarley knock if there was no bearings, thats why it is all so da** puzzling to me
bsbllfit7 is offline
Old 07-01-2008, 05:34 PM   #18
Engine: 2.5 T2
Images: 14
You weren't "overly-tired" when you took it apart were you ?
ol"blue is offline
Old 07-01-2008, 05:36 PM   #19
nope wasnt drunk or tired, and i put everything on a table as it came out in the order it did so it can be reassembled like it was, no bearings for piston number 3 lol
Old 07-01-2008, 05:42 PM   #20
Engine: 2.5 T2
Images: 14
I guess we'll have to blame this one on the aliens too.
ol"blue is offline
Old 07-01-2008, 05:47 PM   #21
lol which aliens, the illegal ones or martians I know i havent seen any martians around here but boy have i see a bunch of illegal aliens!
Old 07-01-2008, 06:01 PM   #22
Engine: 2.5 T2
Images: 14
Technically, the UFO pilots are also illegally here. But then if you ask the Native Americans, so are the majority of us.
ol"blue is offline
Old 07-02-2008, 02:51 AM   #23
My Ride: Dodge
I call BS. We need pics.
If there truly is NO bearing, that motor would have rattled your teeth out and then come apart in a dramatic manner very quickly.
The Dude is offline
Old 07-02-2008, 05:42 AM   #24
what will pics prove though, all i have to show is 4 pistons on a cart, and 6 bearing shells, missing the two from the 3rd piston, and maybe the scores and scratches from the journal might show up but i doubt it, ill take them tomorrow anyway, the remainder of the bearings were pretty bad though, looks like oil starvation was the reason for them going down the crapper
Old 07-02-2008, 06:54 AM   #25
My Ride: Dodge
I would appreciate the pics. Try to get decent pics of the big end of the rod, opened up, and the rod journal on the crank that it came off of.
The Dude is offline
Old 07-02-2008, 10:32 AM   #26
My Ride: 86 SC & 98 Neon
1/4: 9.900
You spun a bearing. They get squeezed out of the sides like toothpaste once they spin and damage begins. Look for pieces of metal in your oil pan that look like thin peices of razor blades.
DblTrbl is offline
Old 07-03-2008, 10:26 AM   #27
That sounds like the most logical explanation. I'm doing a bearing change right now and the number 4 did just that.
86daytonaZ is offline
Old 07-03-2008, 03:05 PM   #28
well i did drain the oil just prior to pulling the motor so the pieces could be in there, there was also some tiny particles stuck in the oil pickup screen, im not sure if they are bearing fragments but it is metallic i believe
Old 07-08-2008, 12:38 AM   #29
My Ride: 89 lebaron coupe
Engine: 2.5 t1
does the rod look all black/blue and burned on the big end? We had a slant 6 in the shop, and it had a wicked rod knock. When i pulled it apart, it also appeared that there wasn't a rod bearing. The rod was completely black. It seems that the rod bearing tried to weld itself to the rod. The shells were a pain in the ass to remove from the rod
lucky13 is offline
Old 07-08-2008, 12:43 AM   #30
nope the rod and journal look completely normal, the engine is now entirely dismantled and there are still only those 6 rod bearings. idk what coulda caused that but the journal and the rod bore itself arent that badly damaged, although they are more worn then the other rods and journals
Current Accounts | Mobile Phones | Share Prices | Israel Hotels | Loans
Page generated in 0.51779 seconds with 14 queries
