06-30-2008, 04:59 PM
Rod Bearing Missing with piston removal!!!!
My Ride: 1988 shelby z
hey everyone i just started taking apart my block today and noticed that the wearings were excessively worn, it looks like from oil starvation. On the number 3 piston there was no rod bearing on the upper or lower half of the rod or cap!!!! Could this have happened from just running the engine or did the re**** that rebuilt this last forget to put on bearings??? I have a hard time believing that someone could be that stupid
06-30-2008, 06:26 PM
Re: Rod Bearing Missing with piston removal!!!!
no there was no knock really until recently and i believe that to have been more of a rapping from valve train noise as it would not always be there, so no it didnt really have a knocking problem and usually ran pretty well too, and now when i pulled the pistons there is no bearings on cylinder 3
06-30-2008, 08:50 PM
My Ride: '89 Daytona Shelby
That engine had to be banging away like no bodies business ... your neighbors three doors down heard it. ... unless the shells are in your pant cuffs.
06-30-2008, 08:55 PM
there are only 6 shells for the bearings and no there wasnt any knock lol, idk how the hell this happened and for that matter idk why the hell it is the way it is but there were only 6 bearings and no knock
07-01-2008, 04:28 AM
no i am just now rebuilding the engine so it wasnt my mess up, and if it had spun the bearing there would have been a knock for awhile, atleast for the bearing to completely dissapear
07-01-2008, 09:26 AM
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
That crank journal would be all dented up and scarred like a mofo if run w/o a bearing.
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
07-01-2008, 01:52 PM
out of all the journals on the crank it is the only one with any scarring, its still not even too bad but if you run your finger over that specific journal you can feel scratches and scours.
07-01-2008, 02:44 PM
#12
My Ride: 86 Laser XT
Engine: 2.2 turbo
Are you sure there are no bearings???
No evidence at all?
That journal would be SCREWED with out a bearing and audible knock would be a definite
07-01-2008, 02:57 PM
#13
thats what i was thinking too but i am 100% positive there is no bearing anywhere within the engine, almost everything is dissasembled, the only thing left in is the crank and there was no sign of those two bearing shells anywhere!
07-01-2008, 03:53 PM
#14
My Ride: 85 Shelby Charger
Engine: 2.2 T-II
So how long did you run this engine with no rod bearings? If you did run an engine without the rod bearings, the rod would come apart almost instantly. We need pics.
» Dodge Turbo Chat |
| Title, Username, & Date |
