Old 07-05-2008, 06:58 PM   #1
2.5 Crank Differences
My Ride: 1989 Daytona ES
Engine: 2.5l Turbo
Feedback: (8)
I was wondering if there was a difference between Turbo and Non-Turbo 2.5l Cranks. I am looking at doing a 2.5l Turbo build and have found plenty of 2.5l N/A cranks for sale, but no 2.5l Turbo cranks. Thanks.
1983Rampage is offline
Old 07-05-2008, 07:08 PM   #2
Re: 2.5 Crank Differences
exact same even has same part #
allmotor is offline
Old 07-05-2008, 07:09 PM   #3
Engine: 2.5l Turbo
Feedback: (8)
Sweet, thanks. Never have been able to find info on if there were a difference.
Old 07-05-2008, 07:41 PM   #4
There are some 2.5 crank differences. the tall block 2.5 has a little taller counter weights that just nick the bottom of the pistons if you use it in a common block. And a Dakota crank will have a removable pilot bearing for the trans.
22dodge is offline
Old 07-05-2008, 07:42 PM   #5
Engine: 2.5l Turbo
Feedback: (8)
But all 2.5l CB Cranks will be the same if they are from a car then, right?
Old 07-05-2008, 07:49 PM   #6
I guess my English is poor. ALL 2.5 cranks have the same stroke. Older tall blocks will fit common blocks but you need to grind off casting flash from the counter weights. Dakota 2.5 cranks will have a pilot bearing. ALL turbo and N/A common block cranks (except dakota) are the SAME part, have the SAME part number, and are EXACTLY the SAME
22dodge is offline
Old 07-05-2008, 07:51 PM   #7
Engine: 2.5l Turbo
Feedback: (8)
Ok, good, I just wanted to make sure I knew what I was wanting to look for and what I should stay away from so I do not have to do any modification in order to use. Thanks guys.
Vegas Hotel | Free Ringtones | Loans | Car Insurance | Find Local Jobs
Page generated in 0.28099 seconds with 13 queries
