Old 07-08-2008, 03:48 PM   #1
2.5cb n/a build out of 85 2.2 turbo
My Ride: 88 dodge daytona
Engine: 2.5 cb all turbo
hi just making sure i got this right.i got a 85 2.2 turbo with good rods and pistons that i want to put in a 91 2.5cb n/a motor.i can just change rods and pistons and put the g head on and i should be ready to go right?im going to remove balance shaft and plug oil hole,do #4 cooling mod,and put intake and ported exhaust and turbo off my 88 t2 motor and swork on a custom cal based on the ladybug code.as of right now im running a 2.5 n/a bottom end with a turbo and custom cal having fun blowing it up....my 88 t2 motor popped a wrist pin out and ruined the block and i have 3 2.5 cb n/a motors lying around so i thought id do some fun destruction while im building a good motor.i love the added torque and of the 2.5 with all that compression but she startes knocking around 6 psi.i turned the knock senser down so it dont pick it up and turn down timing till about 12 psi.been driving the snot out of her for 3 weeks now and playing with the cals just learning what differant stuff does without worrying about hurting a good motor.ohh onemore thing i know the cam is retarded 4 degrees being 2.5 n/a but is that why egts are super hot at idle (2250+)but go down at 3000 rpms and above?
jrye68 is offline
Old 07-08-2008, 03:56 PM   #2
Re: 2.5cb n/a build out of 85 2.2 turbo
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
Uhhh.... what?
Tim_K is offline
Old 07-08-2008, 04:06 PM   #3
what do u mean by that?
jrye68 is offline
Old 07-08-2008, 04:16 PM   #4
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
WTF.... If you are set on a 2.2...
Take one of those CB 2.5's and go get an 89+ 2.2 crank and 2.2 turbo pistons and have a nice day.
leave the 85 block out of the picture... completely
Edit: you'll have to fab up a turbo oil return line to the pan... no big deal
even sweeter if you can grab the 2.2 CB pan.
Screamin4banger is offline
Old 07-08-2008, 04:23 PM   #5
i was just going to use the 85 turbo rods and pistons and put them in the 91 cb.use the 2.5cb cast crank with turbo pistons would work right?
jrye68 is offline
Old 07-09-2008, 09:19 AM   #6
Nope wont work at all!!!! To attempt to educate you. Go to United Engine and Machine Co.. look up the specification for the 2.2 pistons and the 2.5 common block pistons, then report back as to what you found out. This is your assignment. If you are successful you earn and A. If you get the answers from someone on here without doing any work on your behalf to solve this answer, you earn an F.
22dodge is offline
Old 07-09-2008, 01:39 PM   #7
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
Got to Donovan's Dodge Garage for education also.
cawcislo is offline
Old 07-09-2008, 01:46 PM   #8
My Ride: 87 Shelby Charger
Feedback: (6)
you never fail, to crack me up with your remarks
Juggy is offline
Old 07-09-2008, 05:46 PM   #9
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
not to mention the rods are the weakest rods out there, and the block is also the weaker of the avaliable blocks.
hell if anything, id do a common block 2.5 with early non commonblock 2.5 rods, g head etc. 2.5 common block turbo "motors" arent hard to find and will save you a hell of a lot of headaches and cussing!
crusty shadow is offline
Old 07-09-2008, 06:54 PM   #10
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
Only disagreeing with the rod statement.85 turbo rods are the same as T2 andT1 2.5 rods except they aren't bushed pins.86 had the L/W rods.non CB 2.5 rods are "long rods"used in tall block 2.5s.would have to have custom pistons to use in CB.
4Daytonas is offline
Old 07-09-2008, 06:54 PM   #11
didnt u read that he wants to put 1985 2.2 rods and pistons into a 1991 2.5 common block?
i got a couple 2.5 turbo motors laying around 1 has 85k miles the other has 117k miles. $100 each u pull.
allmotor is offline
Old 07-09-2008, 07:00 PM   #12
Engine: 2.2-2.5
To do what you want to do you can use the rods and pistons in a common block but you would also need a CB 2.2 Crank.
Old 07-09-2008, 07:36 PM   #13
aw, come-on let the guy figger it out himself. i like the grading option.
allmotor is offline
Old 07-09-2008, 08:35 PM   #14
the grading would be fun. he has to post a vid of it when hes trying to start it though
i was only off one year on the rods.
Old 07-10-2008, 01:30 AM   #15
ok 22dodge i see from the link that the 2.2 wrist pin would need to be higher up on the piston for it to work in a 2.5cb..do i get a A? allmotor where u located?
jrye68 is offline
Credit Cards | The eBay Song | Mortgage Loans | Online Loans | Credit Card Debt Consolidation
Page generated in 0.48506 seconds with 13 queries
