Old 07-28-2008, 06:27 PM   #1
What happened here
My Ride: Magnum
Engine: 2.5 TII
Hey guys I need a litle help here, my setup is a 2.5CB with std forged pistons, almost all of the bottom is forged, 8v ported head, TBI roller cam, Holset turbo, Big front intercooler, Megasquirt and some other goodies....
Well I hope you can tell me what is your first thought when you look at this piston:
This is the 4th piston still inside of the block:
Its a forged JE piston
This Picture was taken one week before the damage:
I guess it was too much timing and also could be some heat, but I will need more thoughts please.
Thanks.
R/Tony is offline
Old 07-28-2008, 07:25 PM   #2
Re: What happened here
Feedback: (32)
Ran lean.
I'd get a new block.
tryingbe is offline
Old 07-28-2008, 09:17 PM   #3
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
Shit son... Even forged...
Ya prolly ran lean would be my bet.
Old 07-28-2008, 10:05 PM   #4
holy detonation. looks like my stock 2.5 piston did after 27psi on pump
8valveprick is offline
Old 07-28-2008, 10:22 PM   #5
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
I disagree with everyone. What was the piston --> cylinder wall clearance set at?
phantomrt is offline
Old 07-28-2008, 11:51 PM   #6
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
you can clearly tell that there was detonation from the pitting on the pistons. I bet the head has similar marks. Also if the ring gaps were tight that could have been a secondary issue
speeduphoria is offline
Old 07-29-2008, 12:34 AM   #7
My Ride: 85 laser
Feedback: (7)
Yep detonation attacked the weakest part of the piston must have went lean or overheated, How much boost were you running and what octane ?
jim34 is offline
Old 07-29-2008, 06:40 AM   #8
My Ride: 88 Shadow
Feedback: (7)
Had the exact same thing happen to me, that is a lean condition right there. My FPR turned out to be faulty, staying at base pressure not adding for boost.
What was your A/F ratio?
The piston to wall clearance *may* have had an affect if it was set too tight, but being too tight would not make that happen on it's own. There was definite detonation, and when the top breaks off like that it's a lean condition detonation.
moparzrule is offline
Old 07-29-2008, 12:58 PM   #9
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
You mean was?
Sittn86 is offline
Old 07-29-2008, 06:53 PM   #10
My Ride: 87 SHELBY DAYTONA Z
Engine: 2.2 T2
i agree way to much detonation! what kind of guages you running? 3 bar map? as you can see i is definalty worth the money to get a GOOD A/F RATIO GUAGE... i use the AEM's wideband UEGO guage and i've never had a problem with it.
lancerman23 is offline
Old 07-29-2008, 08:39 PM   #11
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
Too much boost, not enough octane and gas. PING PING PING!
Ouch!
Same happened to me went to 18-19psi with a cal that did not know wtf was happening above 15psi. Live and learn- did you have an eye on egts? I was running maybe 11s on the wb and 1600s egts- funny thing is that the hose popped off the wastegate can and I hit 29psi with no damage a few weeks before- but the air was much cooler then. Time for a new block and piston.
dyno sheet
I practice what I preach:
1992 GTC convertible 2.5/568 aluminum fw/Tu 6puck feramic/s60/3in Tu sv/+40S/ FWD CAL /FMIC/self ported head+1mm exh valves/self ported ex mani/stock 2piece w/stock tb/PSSSSTSSSS
crazymadbastard is offline
Old 07-29-2008, 08:48 PM   #12
My Ride: Magnum
Engine: 2.5 TII
Well I dont think it was lean condition... check this log:
It was running rich (10:1 AFR in a LC-1) and it was not hot Im sure... the only reason could be detonation, I was using premium gas with toluene and xylene, with about 20psi of boost.
Yeah... It was way too open ! it was something like .010 or .012 dont recall the exact value at this time.
R/Tony is offline
Old 07-29-2008, 09:11 PM   #13
My Ride: Magnum
Engine: 2.5 TII
Do I need to change the block ?
I have already bought the pistons, but also the block ? and why ?
R/Tony is offline
Old 07-29-2008, 09:17 PM   #14
heat. heat broke that piston. did you make sure you bled the cooling system ???
if not then thats detonation. i dont care if it shows it running rich.
mopartech is offline
Old 07-29-2008, 09:18 PM   #15
My Ride: SOLD!
If only that piston did that, then I'd say it was a wiring/injector problem with a possible ring gap issue.
Cylinder goes lean, heat expands the ring, piston fatigues and crack goes your JE.
If all are experiencing that issue, then check to make sure the logging software is reading right. Also, iirc while using toluene and xylene I think you need to run richer of an afr.
Gutfeeling is offline
MPAA | Loans | Loans | Credit Card | Bad Credit Mortgages
Page generated in 0.42958 seconds with 13 queries
