Old 04-23-2003, 08:26 AM   #1
crank sprocket removal?
My Ride: Lebaron convertible
Any suggestions on how to remove it? Thanks
STANNN is offline
Old 04-23-2003, 10:43 AM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 turbo II
You will have to get a puller. I made one of my own using an old headbolt and a piece of steel. You will have to put something in the crank where the bolt goes for the headbolt to push against. I used a bolt and washer that was smaller than the crank/sprocket bolt.
ShelbyGLHS592 is offline
Old 04-25-2003, 08:36 AM   #3
puller
I tried a steering wheel puller, but that didn't line up correctly. I'm trying to avoid buying a tool I wouldn't use somewhat regularly.
STANNN is offline
Old 04-26-2003, 12:54 AM   #4
cam sprocket removal
Did this a few weeks ago. I would have bought one but couldn't find one anywhere So I went down to the hardware store and found this shelf bracket for about $4. I already had a hole saw and a couple of bolts and vola! It held the sprocket in place while removing the bolt. It tweeked a little but did the job. As a matter of fact I'll be using it again on the "unknown rampage". It too has a blown headgasket. Chris
trooper is offline
Old 04-28-2003, 09:54 PM   #5
bolt
Yeah I got the bolt out with no problem, but the sprocket.......
STANNN is offline
Old 04-28-2003, 10:27 PM   #6
sprocket
Are you trying to maintain the timing? If so are you planning to put the belt under tension? I zip tied the belt to the sprocket before removal and took a bungie and hooked it to the sprocket
to keep tension on the belt so as to not loose the cam timing. Chris
trooper is offline
Old 04-28-2003, 10:37 PM   #7
I don't know if Autozone still does it, but they used to have a "loan a tool" program. You buy the tool at full price, use it, return it, and get all of your money back.
Old 04-29-2003, 01:35 PM   #8
autozone
Closest thing they have to working is a P/S pulley puller. I thought about trying it, putting it around the bolt heads, but I don't want to screw something up.
STANNN is offline
Old 05-04-2003, 07:08 AM   #9
rEk666
the p/s puller won't work, I spent a half hour a while ago trying to get that darn sprocket off to no avil. Use a steering wheel puller where you thread 2 bolts in to the holes on the sprocket (sort of looks like a peace sign) and use the bigger bolt to push in on the crank so the sprocket pops off.
Old 05-04-2003, 07:55 AM   #10
S/W puller
That's what I tried to use first, I'll try it again today, thanks.
STANNN is offline
Old 05-06-2003, 11:38 AM   #11
crank sprocket
turbonut
Just make one. Use your crank pulley as a template. Use some 1/2" steel and lay the pulley on the steel and just use a marker to mark your holes. Drill them out and tap the center hole with a 1/2" tap. I welded a nut on the end of the long threaded rod so it wouldn't damage the threads on the crank snout. Cost=nothing. Works perfect and it also works on the intermediate shaft sprocket.
Old 05-08-2003, 07:10 AM   #12
My Ride: 91 Spirit R/T
Engine: TIII
Anyone have any tips for doing this on a 5 bolt late crank? I'm not in school anymore so i can't run over and raid the CAP program's special tools anymore. The CAP program is Chrysler's technician apprentice program run through the vo-tech I went to.
86Shelby is offline
Old 05-08-2003, 08:08 AM   #13
5 bolt
That's what I'm working on too, I think I'll try turbonut's suggestion.
STANNN is offline
Old 05-13-2003, 04:25 PM   #14
There's one on Gary's website that I just looked at. You said you had access to a welder, right? Shouldn't be too hard to rig up, just like turbonut said.
supercrackerbox is offline
Cell Phones | Yahoo Personals Coupons | Credit Cards | Credit Cards | Guitar Lessons
Page generated in 0.44335 seconds with 13 queries
