08-17-2008, 07:44 AM
Re: Previously O-ringed Block W/Pics
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
its hard to tell from the pic, but does the chip extend to the cylinder bore ?
in that case, you may be screwed, cuz I'm guessing that will be a point where hot combustion gases will quickly eat away at the fire ring of the HG
if thats the case, I think you should have the block milled (again - is there a max amount of removal allowed ?)
or a good welder could put a tack there, filling the divot, and you could file it flat with a flat file
if 'Ouchie' doesnt extend to cylinder bore I would run it with a cometic and studs - both of which are a good investment and reusable
