Old 09-18-2008, 01:25 PM   #1
2.2 c/b same as 2.5 c/b?
My Ride: 1986 Daytona Turbo Z
I was just wondering if the 2.2 and 2.5 c/b's are the same. Could I get a 2.5 block and put a 2.2 crank and set of pistons in it and the rest of the accessories still bolt up? I have searched on this site and google, but couldn't find anything definite. I am sorry if this is a dumb question.
zippitta is offline
Old 09-18-2008, 01:36 PM   #2
Re: 2.2 c/b same as 2.5 c/b?
My Ride: '88 Horizon TBI
Engine: TBI 2.2
1/4: 17.330
well, i dont have a certain answer seeing as how ive never touched a 2.5 cb
but going on what common sense wrote as for the pistons im thinking no, im not sure about the crank.
im still learning this turbo dodge thing myself lol
so someone set me straight lol
nickskates4lyfe is offline
Old 09-18-2008, 02:06 PM   #3
My Ride: Turbo Minivan
Engine: 2.5L
Yes, hence the name common block. Though, you'll have to plug the oil feed for the balance shaft.
ibrake is offline
Old 09-18-2008, 03:59 PM   #4
My Ride: Starion
i guess the word "common" could be a clue.
common block 2.5 and 2.2 use the same block and same rods, but different crank and different pistons and oil pan and 2.5 has balance shafts except in dakota and pickup tubes for the oil pump are different
pobort is offline
Old 09-18-2008, 05:37 PM   #5
That is what I assumed, but we all know what assuming does. It makes an "a$$" out of "u" and "me." So I was double checking before I purchased a 2.5 block. So all I need to do is plug the balancer oil passages and everything else should bolt right up...am I correct?
zippitta is offline
Old 09-18-2008, 09:48 PM   #6
My Ride: dak,'tona,'baron, sc
Engine: 3.9& 2.2/2.5
let me check, but i think the block bore size is diffrent, even though it a " common block "
83sdc is offline
Old 09-18-2008, 10:04 PM   #7
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (10)
No, bore is the same. What makes the difference between the 2.5 and the 2.2 is the crank and pistons, and in terms of the Turbo rods, they are also the same. But the crank has a larger sweep which increases the displacement. You can take a 2.2l block and put a 2.5l crank and a 2.5l pistons and have it working properly. That is what I have in my car right now. The only real difference is from the TBI blocks. The 2.2l TBI blocks were not cross drilled, where the 2.5l after 90 were. And the 2.2l TBI's did not have balance shafts,as well as the T1 and T2 2.2l cars.
1983Rampage is offline
Old 09-19-2008, 07:05 AM   #8
My Ride: Starion
yes yes yes yes it will work!
pobort is offline
Sauna | Song Lyrics | MySpace Backgrounds | Free File Hosting | Credit Cards
Page generated in 0.43574 seconds with 13 queries
