Old 05-21-2003, 04:51 PM   #1
Oil Pressure sending unit.
Well i discovered that I am leaking oil from my oil pressure sending unit! I didnt even think about that at first. Makes sense now though I guess.
Is this a common problem?
mad_ is offline
Old 05-21-2003, 04:54 PM   #2
Yep. Leaking at the top, right? The rubber membrane inside breaks, and the sensor fills with oil. Around the top bolt is the only place it can come out.
lametec is offline
Old 05-21-2003, 04:57 PM   #3
sounds like an autozone fix right?
mad_ is offline
Old 05-21-2003, 05:02 PM   #4
Sure, although I've had horrible luck with aftermarket sensors. They've started indicating low pressure after a few months.
lametec is offline
Advertising | Libros recomendados | Houses for Sale | Debt Consolidation | Myspace Proxy
Page generated in 0.38985 seconds with 13 queries
