Old 08-05-2009, 09:47 AM   #1
need help switching motors
My Ride: 98 r/t neon
ok so im in college .. at wyotech and i drive my 89 shelby daytona up here well 2 days after i get here it starts smoking.. alot .. and a few days later that special little knock came from the bottom of the block(rod bearing) on the number 1 rod so i take it all the way down to the block. and i find that the wrist pin lock came off and absolutly killed one sleve like im talking some bad junk. and it collapsed the top of the rod on one ring and well it was letting oil up through on top of the piston. and taking it all from the bearing. well i found a 2.2 from and earlyer turbo dodge looked like it was carborated with the airworks turbo... ? i bought it for 50 bucks im putting all my turbo 2 stuff on this motor and using it in the car for right now till i can get everything done with my other one. the only really big diff is this is the weaker block i know with the weaker rods and pistons . and its the 6 bolt crank instead of the 8 bolt ....so i had to get a flywheel for a 6 bolt ...which was very hard to find in my area. and that was pretty much it i really need to know someone elses opinion on this i mean i was at like 13 lbs of boost with my other motor what should i restrict this 2 im running a break in period and getting a full flush of fluids on this as im really scared of internal rusting. so your opinions are appreciated and i know im down grading but i have no other choice as of right now ..
thanks kalem
kalemhicks is offline
Old 08-05-2009, 12:02 PM   #2
Re: need help switching motors
Feedback: (14)
The n/a piston won't last at any boost level at all. Junk it and get a TURBO engine or make your car n/a.
thinkofhairy is offline
Old 08-05-2009, 02:11 PM   #3
ok if i didnt say it before this motor was turboed it was the old airworks turbo on it. it wasent an na motor. it was turboed 2.2 out of o say and 84 through 86 it looked like it was carborated with the turbo running up to the bottom of it? idk if that was first style fi or what?
Old 08-05-2009, 07:23 PM   #4
Feedback: (14)
TI log engine.
You can run about 14psi on it without problem.
Old 08-06-2009, 09:27 AM   #5
ok thanks bud i appreciate it..
kalem
Old 08-06-2009, 10:35 AM   #6
All Turbos
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
Feedback: (10)
The 84-85 Turbo engines are pretty strong.They had the good rods and the pistons are as good as any Mahle cast piston.The blocks are strong enough for at least 300hp.The 86 is the junk turbo engine(weak rods).What happened to your engine can't happen with the pressed pins of the early engines. Pin locks and floating pins are only to make assembly easier IMHO. Also The early engine will have the good G head but while it will run okay in the 89 ,a little more timing should be in order(up to 16 degrees).A custom cal would be optimum but I understand you're only using this engine till you rebuild your 89, so just drive it as is, it'll be fine.
4Daytonas is offline
Old 08-06-2009, 10:50 AM   #7
ok man thanks alot for your help its greatly appreciated
kalem
Old 08-06-2009, 10:59 AM   #8
thanks alot for ya help man its greatly appreciated
kalem
Old 08-06-2009, 02:10 PM   #9
and how would i turn the timing 16 degrees
Old 08-06-2009, 02:14 PM   #10
All Turbos
4Daytonas's Avatar
Engine: 2.2-2.5
Feedback: (10)
Use a timing light in the tranny window set on 14 then turn another 2 degrees(EST).
Old 08-06-2009, 02:23 PM   #11
ok thanks man ill do that the motor is going in either today or in the morning thanks for ya help bro
Old 08-06-2009, 10:01 PM   #12
Feedback: (14)
Stock timing is 12 degree.
Old 08-06-2009, 10:57 PM   #13
MegaSquirt evangelist
UnaClocker's Avatar
My Ride: '90 Voyager LX
Engine: 2.0L DOHC
Feedback: (6)
Thank you captain obvious. It needs to be 16 to offset the slow burn head. I've driven a G head on a swirl calibration, and then swapped in a G calibration. It's night and day. So much more off-boost performance that you'd swear you didn't need boost anymore.. So yeah, an extra 4 degrees will help a little bit, definitely still safe.
UnaClocker is offline
Old 08-09-2009, 06:49 PM   #14
My Ride: 1985 GLH Turbo
hello i was just wondering where can i find parts for a omni glh thanks(1985)
ppimpomni is offline
Old 08-09-2009, 08:05 PM   #15
UnaClocker's Avatar
Engine: 2.0L DOHC
Feedback: (6)
The ForSale section of this forum? What particular parts?
Page generated in 0.27558 seconds with 11 queries
