07-16-2003, 01:27 PM
The rods will fit the block and crank, yes.
Stock TII (assuming "forged crank" means you're using TII stuff) pistons have floating pins, while the '84 rods use a pressed pin.
You're either gonna have to get pistons for a pressed pin (going to a bigger pin would be a good idea at the same time since you're doing the machine work anyway. I think it's a Chevy .912" pin that's commonly used) or have the rod drilled/bushed for floating pin.
I'd go for pressed, bigger pin.
