Old 07-21-2003, 03:46 PM   #1
rods
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
Hello,
has anyone taken a set of 84 rods (beefy pressed pin) and machined out the small end for a bushing for floating pin pistons?
is there enough beef to bore them out for the bushing? if no one has ill be holding them up side by side to a t2 to determine. thanks
Brian
Aries_Turbo is offline
Old 07-21-2003, 07:24 PM   #2
The best rods to use are the TII ones (which require a floating pin piston) or the 81-85 2.2 rod (which do not). Basically the same rod except no bushing for a floating pin
From DDG.
I guess that means you can bore them out for the bushing, although I would just use the TII rods if you have them sitting around.
mpbiv is offline
Old 07-21-2003, 10:49 PM   #3
Engine: 2.5L T2
Originally posted by mpbiv
From DDG.
yeah i saw that...this isnt for my k car....this is for my glh...i have a LW rod and a T2 rod on my desk at work and the LW looks questionable for machining....however i havent cracked the L bodys motor yet to check out the older rod small end to see. if its similar to the T2 in size then ill be machining and doing a quick cheap used part (plus new rings and bearings and some seals) rebuild for my glh. the k car is much closer to being done though! :big grin:
Brian
Credit Cards | Advertising | Credit Cards | Bankruptcy Certification | Bucay
Page generated in 0.28457 seconds with 13 queries
