10-26-2003, 05:49 PM
#38
1/4: 13.650
Opted for the 2.2 common block pan on my 2.5. I have some good things and some bad things to say. OIL: i use 4.5 QTS...gotta love it.
I used the 2.2 pan for this reason.:
With out the balance shafts, all that oil in the pan, albeait good to have extra oil capacity, can be bad. THe consensus on this list had said on many other posts on this subject is that a 2.5 pan with out the shafts, allows the oil to be blown up the sides of the pan, when the crank is spinning. or when the car corners, causing possible oil starvation issues. Ever try to hold a bucket filled to the brim with oil steady??? HEHEHE good luck. THe oil is quite likely to move around, so this therory is sound.
So i went with the 2.2 pan....but now i think there is another issue with this set up. The 2.2 pan has less volume, and the 2.5 crank obviously causes more windage in the pan due to it's longer stroke. Hence theroetically, less oil in the pan, and possible oil starvation issues.
The best selection would be a 2.5 L pan with a windage screen or baffle. This would be the smart way to go. Unfortunately, they are a bit pricey.....oh well.
Joe
