07-26-2003, 10:28 AM
Re: Re: Re: removing balance shaft
Originally posted by joffficer
Not being a smart A$$, but why grind the head off? Is there a clearence issue? If not... it might be wise to saftey wire it so it won't back out. (which I might do if the head can stay)
Good question...I ground it off so it would be flush with the block. The bolt goes in at an angle so the head would have hit the pan.
Again...I used strong Loctite on the bolt. It won't come out.
