Old 07-27-2003, 02:31 PM   #1
'88 vs. '87 TII Crank
Both are in great condition and they both came out of an Innercooled Daytona. Which one is better to use for a High Horsepower motor?
And which Block to use, '88 vs. '87?
Please help!!
Thanks!!
Shelby85Charger is offline
Old 07-27-2003, 06:45 PM   #2
My Ride: 1987 Shelby GLHS 189
They are the same... block and cranks
glhsken is offline
Old 07-28-2003, 09:15 AM   #3
How can you tell the difference between a TI Crank and a TII Crank? Both being Stock Cranks?
Is there any part numbers that would tell me anything?
Old 07-28-2003, 10:14 AM   #4
TII cranks, being forged, you can see the machine marks in the counter weights. The cast cranks are just thet.. cast and and have that rough cast feel.
glhsken is offline
Old 07-28-2003, 02:51 PM   #5
And the recommended one to have for higher horsepower is.....
Old 07-28-2003, 05:42 PM   #6
Cast
According to the wisest of wise, Gary D., the cast is probably better, given it's lighter weight and lower rotational mass. However, the exception to this would probably be if you are putting it in a pre 89 block. Then I might go with the forged. This would HELP POSSIBLY with the flexing in the lower end. I'd really like to hear other opinions on this though. I'm pretty new and basing all of this on what I've read. But I have read a lot.
Rescu2000
rescu2000 is offline
Old 07-31-2003, 10:16 PM   #7
My Ride: 91 Eclipse GSX
Engine: 2.0
i personally like using steel cranks(no flex) and can take much more abuse especially on a 16 V motor(high rpms) but not really needed in a 8 V, the difference in steel is a thick parting line where cast has a thin line, the metals sound totally different too, i don't get that ring with a cast like you do with a steel 1.
flybyuin2.2 is offline
Old 08-01-2003, 07:24 AM   #8
Depends on your power level.
I was running the cast in an 88 block. But I was looking to up the power. so I was going to go with either a steel crank in an 88 block, or a cast 2.2 crank in a common block. I have both setups here at home.
Gary says the cast is FINE for common blocks, not pre-commons. I like th lower weight of the cast but am looking at turning the wick up another notch this time
glhsken is offline
Old 08-01-2003, 09:09 PM   #9
Ken,
I'm looking to build at least 250 plus HP. I would this SC to run. I have an '88 Forged crank out of a '88 Daytona SHELBY Turbo Z.
I can also get the block. I still have the '87 motor, complete. What would you recommend? If I should look for a Steel crank that's what I'll do.
Also, would you recommend an '89 Common Block or stay with what I have?
Thanks!!!
Old 08-01-2003, 09:31 PM   #10
Forged is the steel crank.. The 88 or 87 block with the steel crank will survive in a light "L" bdy just fine.
Common block is always the BEST option.. But with a forged crank you should be able to make 250-300hp with no issues.
glhsken is offline
Old 08-02-2003, 12:21 AM   #11
So, does anyone else think a forged crank would help with the flexing?
ieatrice is offline
Old 08-02-2003, 08:02 AM   #12
Flexing
turbonut
Crank walk, block flex, blah blah blah. I've had nothing but good results with the pre-89 blocks. I don't ever plan to push 400 hp through any of these motors so they work for me. I've put roughly 325 hp give or take through a couple with absolutely no problems. I don't doubt the CB is stronger, but the the "oldies" are plenty stout for me. I also use nothing but the steel cranks.
Repair Bad Credit | Credit Cards | Guitar Lessons | Credit Counseling | MPAA
Page generated in 0.43888 seconds with 13 queries
