08-07-2003, 02:26 PM
thrust bearing wear?
Just found a worn thrust bearing on my 2.2 non-common block(Crank is ruined also). I've read that a super heavy pressure plate puts a big load on the thrust bearing surfaces, But mine is an auto. So the question is: Does power braking under boost (15-20 psi) put a forward thrust on the crank that could cause this kind of wear? BTW, the wear is only on the side towards the converter, and all other bearing/crank surfaces look great. Anyone seen this kind of wear?
