Old 08-12-2003, 06:06 PM   #1
Re-ring time. What's it take?
getragguy
What exactely does it take to re-ring a motor. I've got an 86 TI motor out of a Shelby Charger (I believe). I know I need to remove the head, oilpan, and pisitons. What brand rings do you guys have good results with? Should I re-hone the cylinder walls again, even if there is visible cross-hatch. I am only doing this because compression is less than 50 on one, and around 115 on the rest of them.
Old 08-13-2003, 10:03 AM   #2
Do you have the engine pulled from the car?
If so will want to to get the cylinder bores checked by a good shop.
Then see what they say and order a set of rings from Gary.
DakotaKid is offline
Old 08-13-2003, 02:49 PM   #3
Oh yeah, you may want to just pull the head first and see if you have a blown head gasket before you start ripping the entire engine apart.
Just a thought.
Old 08-13-2003, 02:51 PM   #4
getragguy
Would a blown headgasket cause blow by?
Old 08-13-2003, 05:27 PM   #5
My Ride: mostly mopar
No,more than likely not. They do cause coolant blowout though.
BLUEBALL is offline
Old 08-13-2003, 05:45 PM   #6
getragguy
Eh, oh well. I kinda figured that.
Best Credit Card Deals | Rebuildable cars | Best Credit Cards | Mortgages | Cell Phones
Page generated in 0.32418 seconds with 13 queries
