Old 08-19-2003, 12:18 PM   #1
2.2 cast crank?
A quick question. Does a common block 2.2 cast crank have the provisions for balance shafts? Never seen a cast common block 2.2 crank. Thanks, Pat
shelbyvnt2 is offline
Old 08-20-2003, 12:27 AM   #2
Let me rephrase this. Does a common block 2.2 cast crank have the provisions for the balance shaft drive sprocket? Can balance shafts be used with it? The 2.2 forged crank has the 3 bolt holes machined into the end of the crank to bolt the drive sprocket to. I would appreciate any info. Thanks, Pat
Old 08-21-2003, 06:14 PM   #3
NO Democracy!
Nope! I just looked and verified for you.
DirectConnection is offline
Actress | Bad Credit Mortgages | Debt Consolidation | Debt Consolidation | Debt Consolidation
Page generated in 0.29854 seconds with 13 queries
