08-25-2003, 03:06 PM
Please help, Oil pressure problem!
My Ride: 1987 Shelby GLH-S
Ok, I am on my third rebuild in 3 years and the last one was a rod bearing/low oil pressure failure after only 150 miles! I have had the block completely rebuilt with all new parts, all clearances and machine work done by a reliable machine shop. The oil restrictor is in place, the pump is a new Melling high volume (the second one) and when I drive the oil pressure at cold is about 1/2 up the gauge (all new sending units) and drops to one line above the minimium when at idle and warm. It never goes above 1/2 and is much lower when warm regardless of RPM. I don't want a repeat of the last rebuild, I changed the oil after 20 miles and there was copper (very small) in it, not sure if it was left from last time or not. The car runs great, but I don't want to chance it again!!! I think the oil pressure should be higher! Please Help!
Steve
