Old 09-10-2003, 10:45 PM   #1
Balance shaft sprocket?
Is there any reason to reinstall the balance shaft sprocket on the crank if I'm not using them? From what I can tell, "NO" but I want to be sure before I start bolting things together.
TIA
turbojerk is offline
Old 09-17-2003, 06:38 PM   #2
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
I don't see why there would be any reason to reinstall it?
cawcislo is offline
Old 09-17-2003, 06:50 PM   #3
Location: Down back in the shack with the moon in the door
My Ride: 89 Daytona
Engine: 2.5L TII
I did not put mine back in and it runs great. I see no need for it to be put back in.
Bad Vibe is offline
Old 09-17-2003, 07:55 PM   #4
Hey guys, Thanks for the advice. I'll feel better about leaving the sprocket out now that I know its been done and there are no problems. I kind of figured it wouldn't be a problem but I didn't want to find out the hard way
Thanks
Old 10-14-2003, 10:29 PM   #5
I have a crank seal that won't stop leaking so I am going to have to put mine back in. It didn't leak before so I can assume it acts as a slinger.
Old 10-20-2003, 08:14 AM   #6
DarkShadowz1679
Why do that? You should just replace your seal with a newer teflon self lubricating seal you won't have anymore problems.
Old 10-20-2003, 11:57 AM   #7
Whats the brand and part #. I have no problem pulling my engine back out as I need to replace my trans anyway!!!! but it would be nice to stop the oil leak, getting messy under there!!!!!
Old 10-20-2003, 02:23 PM   #8
DarkShadowz1679
If you go to autozone, they should tell you that the replacement seal they have for that is a teflon self lubricating seal, I can't remember if you have a choice between that and the old 1 anymore or not. Ohh crud your in canada, dunno you'll have to look around I guess. Ok, I minimized then went to autozone.com, they only show 1 seal for that now. You'll hafta email em or call em up and ask em if it's a teflon seal. I'm thinkin thats all they make anymore, have you gotten a new seal already? You can order stuff from them online if it's the one. Otherwise I'm not sure where to look up where u are.
Web Advertising | Internet Advertising | Debt Consolidation | Mortgage | Guitar Lessons
Page generated in 0.34426 seconds with 13 queries
